need help
  • July 11, 2024
  • 67 views
How do I setup justĀ for use of Wi-Fi without cable?
If you are using cable modem (SB6183. SB6190) that cannot provide you the wifi without cable because you need to connect separate router to the cable modem to get wifi.
