Newer model of same exact modem in SB6190
I went to upgrade my modem and bought a brand new Arris Surfbord DOCSIS SB 6190 to replace my old modem only to discover when I got home that I had bought the exact one again-same exact product with same model number. I know this is a dumb question but am I to assume that because what I just bought at Walmart is new that it’s components inside WILL in fact be an upgrade since it’s a new one? I mean when you replace a modem you want the latest technology and components.
Since you had purchased sb6190 which is a cable modem 3.0 DOCSIS once again,  but the components will be the same , but if you are looking for a latest technology we would suggest to go for  3.1 DOCSIS modem for more information of the Product Specifications and Description visit our surfboard.com .
  • November 2, 2023
Nope. it should be the same thing.
I’d return it and go with something Docsis 3.1.
Many isp’s are pushing users to upgrade from 3.0 to 3.1.
