I went to upgrade my modem and bought a brand new Arris Surfbord DOCSIS SB 6190 to replace my old modem only to discover when I got home that I had bought the exact one again-same exact product with same model number. I know this is a dumb question but am I to assume that because what I just bought at Walmart is new that it’s components inside WILL in fact be an upgrade since it’s a new one? I mean when you replace a modem you want the latest technology and components.
Newer model of same exact modem in SB6190
Since you had purchased sb6190 which is a cable modem 3.0 DOCSIS once again, but the components will be the same , but if you are looking for a latest technology we would suggest to go for 3.1 DOCSIS modem for more information of the Product Specifications and Description visit our surfboard.com .
