qr code for guest use of wifi
  • May 21, 2025
  • 36 views
HELLO!  WHAT ARE THE STEPS TO GET A QR CODE THAT GUESTS CAN SCAN IN ORDER TO ACCESS THE OPEN/PUBLIC WIFI?
The SB6190 is just a cable modem and does not have any built-in Wi-Fi features. You need a separate router to access Wi-Fi. If you’re using a third-party router—that is, a router that isn’t a Surfboard device—you may need to check with that router’s manufacturer for support.
Could you please help us with your product’s model number?
  • May 28, 2025
yes! SB6190
