Samsung TV lost WiFi connection (SB6183)
  • July 2, 2024
  • 42 views
Our fairly new (5 months) Samsung TV suddenly lost WiFi connection to our network. All other devices (laptops, phones) connect without problem. When using LAN cable TV works fine (but we lose WiFi capability for other devices.
SB6183 is just a cable modem, without inbuilt wifi on it. so you will be using separate router connected to the modem to access wifi in this case if other devices are connected to the wifi and works fine except one device then you need to check with the device settings or you can also check with the router setting but there is no option to change or check on the cable modem sb6183.
