SB6183 - how to add 2.4?
  • December 19, 2024
  • 52 views
I have SB6183 and would like to add a 2.4 ghz wifi option so that I can have both 5 and 2.4 but we are not able to access an admin page. We think the firmware might need to be updated too.
can someone please guide me step by step on how to add a 2.4 ghz wifi option? We use google mesh as well.
thank you so much in advance!
Best answer by Netopia
The SB6183 is a cable modem and does not support Wi-Fi router features.  You will need to configure your Google Mesh system for 2.4 GHz Wi-Fi.
Forum|alt.badge.img+30
  • Rockstar!
  • December 19, 2024
  • December 20, 2024
Like ​@Netopia says, use your google mesh. Thats the router/wifi part of it. The SB6183 is just a modem.
