Good morning everyone,
I’ve been having my internet drop randomly and more frequently now, I have been trying to figure out what’s causing this issues, I have checked my router and went through them to see if it was them, but it doesn’t seem like it. So now I’m checking my modem.
Here is my event log, sorry if its long. I’m just trying to figure out what all this means. I’m assuming this is what’s causing my internet to drop all of a sudden then come back?
My ISP is Xfinity, if there is anything else I can post that can help solve this issue please let me know.
Thank you,
| Sun Nov 20 16:00:03 2022 | Critical (3) | No Ranging Response received - T3 time-out |
| Sun Nov 20 16:19:29 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sun Nov 20 16:20:06 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing |
| Sun Nov 20 16:20:13 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing |
| Sun Nov 20 16:20:26 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing |
| Sun Nov 20 16:20:34 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing; |
| Sun Nov 20 16:20:39 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sun Nov 20 16:21:16 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing |
| Sun Nov 20 16:21:23 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing |
| Sun Nov 20 16:22:16 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing |
| Sun Nov 20 16:23:18 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Sun Nov 20 16:30:21 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing |
| Sun Nov 20 16:30:53 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing |
| Sun Nov 20 16:31:29 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Mon Nov 21 10:36:43 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-ou |
| Mon Nov 28 08:56:18 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing |
| Mon Nov 28 08:56:25 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing |
| Mon Nov 28 08:57:13 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing |
| Mon Nov 28 08:57:13 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Mon Nov 28 08:57:33 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing |
| Mon Nov 28 08:57:33 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Mon Nov 28 08:57:54 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing |
| Mon Nov 28 08:57:54 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Mon Nov 28 08:58:03 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing |
| Mon Nov 28 08:58:04 2022 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing |
| Mon Nov 28 08:58:13 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time ou |
| Time Not Established | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Time Not Established | Critical (3) | No Ranging Response received - T3 time-out |
| Thu Dec 08 13:20:39 2022 | Critical (3) | REG RSP not received |
| Sat Dec 10 12:27:24 2022 | Critical (3) | REG RSP not received |
| Time Not Established | Critical (3) | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out |
| Fri Dec 16 20:40:28 2022 | Critical (3) | REG RSP not received |
| Fri Dec 16 20:41:50 2022 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing |
| Fri Dec 16 20:41:55 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Fri Dec 16 20:42:23 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Fri Dec 16 20:42:54 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Fri Dec 16 20:43:27 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Fri Dec 16 20:43:42 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Fri Dec 16 20:43:59 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Fri Dec 16 20:51:14 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Fri Dec 16 20:51:14 2022 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing |
| Fri Dec 16 20:51:29 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Fri Dec 16 20:51:35 2022 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing |
| Fri Dec 16 20:51:53 2022 | Critical (3) | No Ranging Response received - T3 time-out |
| Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing; |
| Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing |
| Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing |
| Fri Dec 16 21:00:50 2022 | Critical (3) | REG RSP not received |
| Fri Dec 16 21:22:14 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Fri Dec 16 21:22:14 2022 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing |
| Fri Dec 16 21:22:17 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Fri Dec 16 21:22:47 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Fri Dec 16 21:29:59 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out; |
| Fri Dec 16 21:33:32 2022 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
| Fri Dec 16 21:34:50 2022 | Critical (3) | REG RSP not received |
| Fri Dec 16 21:36:03 2022 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
| Fri Dec 16 22:12:59 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out; |
| Fri Dec 16 22:13:19 2022 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC |
| Fri Dec 16 22:13:24 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Fri Dec 16 22:14:57 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Fri Dec 16 22:38:22 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sat Dec 17 00:04:57 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sat Dec 17 00:05:29 2022 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC |
| Sat Dec 17 00:05:43 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sat Dec 17 00:06:02 2022 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out |
| Sat Dec 17 00:16:52 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out; |
| Sat Dec 17 00:16:52 2022 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted |
| Sat Dec 17 00:16:52 2022 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 0 |
| Sat Dec 17 00:17:32 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sat Dec 17 00:17:32 2022 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted |
| Sat Dec 17 00:17:32 2022 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 1 |
| Sat Dec 17 00:28:39 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out; |
| Sat Dec 17 00:30:51 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sat Dec 17 00:30:51 2022 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted |
| Sat Dec 17 00:30:51 2022 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 0 |
| Sat Dec 17 00:31:53 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sat Dec 17 03:40:32 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sat Dec 17 06:59:00 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sat Dec 17 07:05:43 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sat Dec 17 08:05:14 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sat Dec 17 08:05:34 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sat Dec 17 08:06:42 2022 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
| Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| Time Not Established | Warning (5) | ToD request sent - No Response received |
| Sat Dec 17 08:07:45 2022 | Critical (3) | REG RSP not received |
| Sat Dec 17 08:25:55 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out; |
| Sat Dec 17 08:25:55 2022 | Critical (3) | Unicast Maintenance Ranging attempted - No response - Retries exhausted |
| Sat Dec 17 08:25:55 2022 | Critical (3) | 16 consecutive T3 timeouts while trying to range on upstream channel 1;; |
| Sat Dec 17 08:27:15 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sat Dec 17 08:27:55 2022 | Warning (5) | Dynamic Range Window violation |
| Sat Dec 17 08:30:03 2022 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out |
| Sat Dec 17 08:30:22 2022 | Warning (5) | Dynamic Range Window violation |
