SB6183 Modem not running at 500 mbps speed internet
  • August 23, 2023
  • 495 views
HI, I have recently connected to Cox Communications and the Geek Squad was here from Best Buy to connect it to the modem and it’s currently running at 250, not 500.  Cox said that I need a software update and it can be done remotely?  Can you please advise?
thank you,
Julia
Hello JK27571
                          SB6183 is a cable modem and can provide above 500Mbps speed so you can access internet on direct connection with the optimal speed according to your speed plan and the firmware is part of the provisioning and is pushed by the ISP. Nothing the end user can update.
Hello JK27571
  • August 25, 2023
Whenever a tech from an ISP says a modem needs a firmware update and to contact the manufacturer, they’re just trying to get you off the line or they don’t know what they’re doing so don’t trust anything they say.
They know the firmware is part of the provisioning when the setup the modem. Its pushed by the ISP.
The 250mbps, is that the speed directly connected to the modem or through the router?
