SB6190 - Bridge Mode?
  • May 25, 2024
  • 274 views
Is there a bridge mode that I can activate for the SB6190 cable modem? I’ve accessed some of the configuration ( modem GUI)  but can’t locate bridge settings. Thanks!
SB6190 is just a cable modem, its a plug and play device so this doesn't have any advanced configuration like bridge mode enable so you can connect router to the modem ethernet port to access Wi-Fi from the router.
