Sb6190 internet and power lights are white
  • September 23, 2023
  • 1633 views
I just started to have issues with zoom connectivity being choppy.
I restarted by Sb6190 and realized the online and power lights show green upon starting up to boot, however once everything is booted and online the lights are white.  Is that normal now?  I seem to be connected to internet and my ISP doesn’t see anything wrong.
Best answer by LoveMyLab
I think this is just a function on how the blue LEDs look when there is ambient light, and a little bleedthrough from the green. You end up with something that looks like a warm white.If you look at the unit from the side in a darker room, I think all that you will see is blue and green LEDs.
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • 211 replies
  • September 24, 2023
