SB6190 Signal Levels
  • September 23, 2022
  • 148 views
Hi folks,
I just found Arris’ specifications for SB6190 signal levels here.
It says the Downstream Bonded Channels power should be between -15dBmV and +15dBmV.  My power levels are at 11.X dBmV to 13.X dBmV.  However, in the provided example, it shows -0.1dBmv to +0.2dBmv.  So my question is this?  Should my downstream power levels be between -0.15dBmV and +0.15dBmV or should it be between -15.0 dBmV and +15.0 dBmV?  If it’s NOT the latter, then I should be calling Cox.
Hello Lareman
Thanks a lot for bringing this question to us. In this case, the right range will be between -15 to 15, meaning that having 11 to 13 will be within range.
Hope this answers your question, please let us know if this is the case.
Hello Lareman
