SURFboard modem lights flashing
  • December 24, 2022
  • 273 views
After a power outage the modem is flashing. All the lights are just like vibrating and nothing happens when attempting to restart it. Any help is appreciated
Forum|alt.badge.img+30
  • Rockstar!
  • 274 replies
  • December 24, 2022
Hopefully your modem didn’t get toast by power surge. Try turning off the power for 10 mins with coax cable disconnected. Then power on, top led should be blinking.  Then connect coax cable to connect the internet.
hope this helps
