To check Ethernet Connection on SB6183
  • February 23, 2025
  • 27 views
My SB6183 modem is working and the ISP confirms I have connection from their side but I am getting no indication via lights that the Ethernet connection is working.  How can I confirm if the Ethernet port is damaged or not?
  1. Click on the Apple menu.
