Unable to connect printer with SB6183
  • January 24, 2024
  • 25 views
my printer cannot connect to the internet its configured to my pc properly but i just realized that my arris router has run out of warranty on dec.17,2024 could this be my problem
  1. No. your warranty won’t impact whether it’ll connect
  2. you posted in the SB6183 section which is a modem only device. It isn’t a router.
  3. What actual router do you have?
  4. did you contact that printer manufacturer. Its the printer that connects to the network, not vice versa.
  • January 24, 2024
