Hello Arris Community! I just purchased a brand new Arris SB6190, but am a little concerned about the power supply. The modem is rated at 12V, 0.75A input, while the power supply that came with it is rated at 12V, 1A. For most electronics, I would only using a matching power supply to avoid damaging the device. Does the modem have some tolerance to make this acceptable, or was I somehow given the wrong power supply with my purchase? Thanks for the feedback!
