The transmit light, which should be solid blue to indicate bonding, is solid green. I cannot find a reference to what this means with respects to the transmit/receive lights.
Please advise.
View originalThe transmit light, which should be solid blue to indicate bonding, is solid green. I cannot find a reference to what this means with respects to the transmit/receive lights.
Please advise.
View originalAre you talking the “send” icon?
If so, when its green, it means non-bonded upstream channel is connected.
You can find it in the manual here.
https://arris.my.salesforce-sites.com/consumers/ConsumerProductDetail?p=a0ha000000REMs8AAH#panel3
