Answer
8-12 Mbps download speed (on 100 Mbps plan) but upload is fine at 10Mbps
  • August 6, 2023
  • 723 views
Hi everyone,
After several hours on the phone with my ISP, they told me several times that everything on their end is fine, that I need to contact the modem manufacturer for further guidance.
My internet plan is 100 Mbps download/ 10 Mbps upload.  For several months now my download speed has been hovering around roughly 10, but my upload has been solid at 10+.  If I reboot the modem the download speed will jump to 15 or so but only for 1-2 minutes, then back down into single digits.
I have this SB8200 modem and a Netgear WNDR4500 router; these speeds are consistent across all my devices, both wi-fi and hard-wired into the router.
For the life of me, I can’t connect to the internet when plugged straight into my modem, but I am able to manually set my IP (like the work around sticky says) and obtain my bonded channel status.  It looks like 5 of them have a SNR/MER below the levels recommended in the FAQ (one of them is 0!), and 6 channels have uncorrectables that are insanely high-- this particular status was obtained only a few hours after rebooting my modem.
I don’t trust ISP’s in the slightest, and would love to have a tech come out and realize that my coax is damaged somewhere or something like that, but I’d prefer to check with y’all before running the risk of eating the $$$ tech fee.
Is there any other info I need to provide?  I don’t know what else to try.  Thank you very much!
Bonded Channel Status
with the errors it indicates a line issue.
If that doesn’t help and you’re still getting the error with the rented modem, they will need to check the lines
The values of Power/SNR on the downstream and upstream channels are within the range,  but the corrected and uncorrectable's need to be on 0 values wherein it shows all of them are in number values. Contact ISP(Internet Service Provider) to fix the same.
All channels on the downstream need to be locked: channel 22 which is unlocked to be on the locked category.
After making the necessary changes as mentioned above, Run a speed test.net to check the speed again. If still the speed is slow then try the steps below:
  • Swap the ends of the ethernet cable
  • Try with different ethernet cables (cat 6/7/8)
As you had mentioned no internet after disconnecting from the router, and directly connecting the modem to the computer, do a power cycle on the modem to obtain a proper IP address and check for the internet.
To do a Power Cycle follow the steps below:
  • Unplug the power and co-axial cable
  • Wait for 30 seconds
  • Plug back the co-axial and then power cable back
  • Wait for the lights to come back on the modem
Also, check the below information:
  • Place the gateway in the center of the house
  • Don’t place it  behind any electronics or appliances
  • Don’t keep it too close to cordless phones (landline not cell), baby monitors, or your microwave
  • Make sure it’s not behind a metal or concrete wall as the signal will be facing a hard time to go through them.
If still no internet check if the co-axial cable is properly connected without any loose ends /cuts or damaged cable then reach ISP (Internet Service Provider).
  • August 8, 2023
Thank you very much for your response!
I contacted my ISP and asked them about the correctable/uncorrectables.  They said it is not their job to fix and that I could pay for a tech visit to troubleshoot on site.  I declined and opted to rent a modem from them for one month to see if the the problem follows modems or not.
I have tried 3 different ethernet cables ( Cat 5e and 6, I don’t have 7 or 8), but the issue has not changed.  I have moved my modem around, and was also able to connect to internet directly after power cycling, with no result.  In the next day or two I will follow the coax through my crawlspace as far as possible to make sure it is not damaged.
I’ll update when I get the ISP modem and let you know if the issue is resolved or stays the same.  Again, thanks!
  • August 9, 2023
