ARRIS SB8200 Minimum ISP plan to use
  • July 10, 2025
  • 25 views
My ISP plan is 200Mbsp. Works for what we have now. And unlimited.  Looking to upgrade from ARRIS SB6182. Will the SB 8200 work?  or is it too much for what we have? Cox cable wants me to get more data speed. Thank you for any info.
It seems like the model you're referring to is the SB6183, which is a DOCSIS 3.0 modem. For future-proofing, you might want to consider upgrading to the SB8200, which is a DOCSIS 3.1 modem.
