ARRIS Surfboard SB8200 question
  • December 11, 2025
  • 169 views
I assumed when I bought this that I could run two ethernet cables from it at the same time because it has two ethernet ports. Just found out that is not possible. One can only run one at a time. Without having to physically switch cables, is there such a thing as a modem switch to multiple devices (i.e. desktop, router, personal server, etc.) without having to move cables?
The SB8200 is a standalone cable modem and does not include a built-in DHCP server. As a result, when your internet service provider (ISP) activates the modem, it typically assigns only one public IP address, which supports a single internet connection.
If you wish to use both Ethernet ports on the SB8200 simultaneously, you would need to contact your ISP and request the activation of a second public IP address. However, please note that not all ISPs offer multiple public IP addresses for residential customers.
For more details on the functionality of the SB8200’s Ethernet ports, please refer to the link below:
 https://arris.my.salesforce-sites.com/consumers/articles/knowledge/SB8200-Ethernet-Ports
If you want to connect multiple devices, you’ll need a separate router connected to the SB8200. From the router, you can then connect multiple devices. Alternatively, you can return this modem and opt for a gateway, which combines both a modem and a router, allowing you to connect multiple devices via Wi-Fi and wired connections.
  • December 11, 2025
Unfortunately Comcast does not have compatible modems for Comcast business which are both modems and routers. To be clear what I was asking is adding a multiport switch between the modem and other devices going to work so I don't have to change cables. So I would only be using one port on the modem and I would connect the ethernet cable to the multi Port switch and then connect the router to that. Is that going to solve my problem?
  • December 12, 2025
You need to router to assign private ip addresses. So it needs to go modem---->router---->switch
You can’t go modem--->switch---->router. It wont work
