CM8200 LAG(LACP) support/SB8200 web interface
  • November 23, 2022
  • 197 views
Hi!
I’ll start with my first question. Does the CM8200 support LAG(LACP)? and also I can’t access my web interface on my SB8200 from a 192.168.0.0/24 network, is this a known bug? It’s not shutdown in the config file. What is the current version of firmware on DigialCM? My ISP (Midco) seems to think that two year old firmware is up to date.
Hello appleeimac
I would recommend to approach ISP for CM8200 as it's been provided by them.
To access web manager page of sb8200 login to 192.168.100.1 also, connect the modem directly to computer /laptop bypassing the router. Some routers may not route traffic to 192.168.100.0/24 outside of Local network.
Let us know if this helps.
Hello appleeimac
