Connecting SB8200 modem with Netgear and Vonage
  • February 17, 2024
  • 200 views
I have an SB8200 modem. Currently, my modem is plugged into my Vonage phone modem, and my phone modem is connected into my Netgear Wifi router. I want to connect my SB8200 directly into my Netgear router and use one of the ports on the router to supply my Vonage modem. I tried this setup; however, I cannot get the Netgear router to recognize the SB8200 modem; i.e. I get no connection into the router.
Best answer by ponder68
Bingo! Thank you very much!
  • February 17, 2024
Power off the modem for around 10 minutes with nothing connected to it.
Connect the coax back to it and power it on and wait a couple minutes.
Then connect the router to port 1 on the sb8200 and turn the router on.
Give it a couple minutes and go through its setup.
  • February 17, 2024
  • February 17, 2024
Glad it worked!
