I am using an external Linear power supply for my surfboard, 8200 modem. Is the diameter of the pin in the power inlet 2.1 or 2.5? Thank you
diameter of the power inlet on the SB8200.
SB8200 | Power required 12vDC | Amperage 2.0A | PIN type POS(+) | Type Wall Wart |
The above mentioned are the power supply details of the Arris modem model SB8200 for more details you can reach out to Arris.com/consumersupport if your modem is under warranty.
