diameter of the power inlet on the SB8200.
  • November 16, 2023
  • 89 views
I am using an external Linear power supply for my surfboard, 8200 modem. Is the diameter of the pin in the power inlet 2.1 or 2.5? Thank you
SB8200
Power required
12vDC
Amperage
2.0A
PIN type
POS(+)
Type
Wall Wart
The above mentioned are the power supply details of the Arris modem model SB8200 for more details you can reach out to Arris.com/consumersupport if your modem is under warranty.
SB8200
Power required
12vDC
Amperage
2.0A
PIN type
POS(+)
Type
Wall Wart
