Downstream icon solid light on (blue) + internet icon solid light (green)
My wifi has been offline for 4 days. Xfinity reporter that on their end the internet system is on and successfully connected. They suggested to troubleshoot my surfboard. I rebooted several times - no luck. Should I factory reset? See title for status lights on my modem.
  • 2275 replies
  • April 10, 2023
do you have more than 1 device connected to the sb8200?
It has more than 1 ethernet port but xfinity only supports 1 device connected to it (unless you pay for a business class line).
If you had more than 1 thing connected, power the modem and the router off for a couple minutes and disconnect the coax from the modem. Wait a bit.
Then connect the coax back to it and power it on. Give it a couple minutes to fully boot
Then connect the router to port 1 on the modem and power the router on.
give it a couple minutes and attempt internet setup on the router.
  • April 11, 2023
Thank you - I followed the steps but no luck. One item to note is that my modem does plug into a a large router that feeds up to 15 different remote expanders throughout the house. There are other components after the modem feeds internet into the house. For example, a surgeX is making noise.
  • 2275 replies
  • April 11, 2023
What router is connected to it?
Does the modem work if you connect a computer to it?
You’ll have to follow the procedure above but using the computer.
  • April 11, 2023
An araknis
  • April 11, 2023
I have not tried with direct line to computer - will do so now
