Answer
Eero poe gateway wont connect to SB8200
  • August 10, 2023
  • 89 views
Have reset the router and had Cox cable confirm
Old netgear router will work and pc ethernet connected to modem connect to internet but
When attempting to set up Eero gateway signals
no internet
The sb8200 is a 3.1 DOCSIS cable modem that provides internet through hardwire for wired when connected to a laptop or computer and wireless when connected to a router.
sb8200 works only with one ethernet port at a time, if want to connect both ports to the internet at the same time, need to activate the second port with a different IP by contacting Internet Service Provider.
After activating the second port now can connect it to a wired device like a laptop or computer and a wireless device such as a router.
