I've been using an SB8200 for years. Has been working fine. Now I want faster uplink speed
  • February 19, 2024
  • 700 views
We installed Xfinity 1000/40 residential service in, I think, 2017, and installed the SB8200 as the modem. It’s been working. (BIG thumbs up! I cannot complain about several years of flawless service.)
When Xfinity bumped service to 1200 a couple years after that, we saw no immediate reason to change modem hardware. Just last week, tho, I discovered that they didn’t just bump it to 1200 down, they also bumped it to 200 up. Nobody talks about the uplink rate. I’ve only been seeing 40 up the whole time since. Well then! I would really like to bump up that uplink rate!
I called an Xfinity tech in, who tested the coax up to 2000/450, and what we’re paying for (1200/200), and then speed tested through the modem: the up link rate was 40 Mbps through the SB8200.
Is there something I can do to the SB8200 that’ll get me to the promised land (200 Mbps up)? If not, is there another Arris modem that fully supports Xfinity Docsis 3.1 1200/200 coax service?
I had just finished that sentence above when Josh from Xfinity called, since they text-asked whether the visit resolved the problem and I replied No. We talked about the tech visit and he mentioned that while the downlink rate was improved some time ago, uplink rate improvements are still happening as a rolling upgrade across our area, and that the bootfile they’re giving me for my SB8200 doesn’t configure it for the faster uplink rate. The uplink rate change has (seemingly) only started to happen as of a couple months ago. So my read of the upgrade situation as stated above appears to be w0rng, the uplink speed wasn’t upgraded with the downlink speed.
Long story short, The list of Xfinity recommended 3rd party modems that take advantage of higher supported uplink speeds atm are: Arris G54, NetGear CM3000 and CBR750, Hitron Coda and Coda56.
Your list is correct in what’s supported currently. Xfinity is adding devices to the list but its been slowly. I hear they’re looking at the s33 but there isn’t anything official. So right now you’re limited to that list.
And the speeds just increased at the end of the year (ish) so you haven’t missed out by much.
  • February 19, 2024
  • February 19, 2024
This page tends to have the latest updates from xfinity on it.
https://www.reddit.com/r/Comcast_Xfinity/wiki/knowledgebase/next-generation-internet/
The list used to have the Netgear CM2050V on it but it was pulled when it was running into issues. Supposedly its being worked on with firmware improvements.
For more information on sb8200, as your ISP is Xfinity  it will support speed limit till 800mbps only .
