Led light status on sb8200
  • January 31, 2024
  • 1537 views
I bought a new unit and on first plug in I see the second blue light on, the other 3 are not lit. What does the 2nd blue light mean?
Here’s what the led’s mean:
https://arris.my.salesforce-sites.com/consumers/articles/General_FAQs/SB8200-LED-Light-Status/?l=en_US&fs=RelatedArticle
Did you check with getting it provisioned?
  • January 31, 2024
sb8200 is a 3.1 DOCSIS cable modem. The LED light status is Power/Receive/Send and Online .
Usually if the second light (Receive) is Blue in color shows  High-speed Internet connection with downstream channels in DOCSIS 3.1 , the other lights might be seen as a light shade of green or white due to the blue light which is highlighted more.
To know more about if the modem is functioning connect the modem directly to a ethernet port laptop or computer and check if it is able to provide internet connection. If not check the IPV4 address .
