missing ssid label
  • September 26, 2023
  • 122 views
My surfboard 8200 never came with an SSID label. How do I get that?
Best answer by LoveMyLab
Could you clarify please? If you are talking about an SB8200, that’s a modem. The SSID is broadcast by a router and is typically user configurable, along with the WiFi password.
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • 212 replies
