modem didnt work out of the box
  • July 23, 2025
  • 46 views
I purchased the modem from Best Buy because my modem was acting strangely. I did not get a chance to install the modem until after the bus by return policy expired. Best Buy recommended me reaching out to you about getting a refund because they were unable to refund or replace the modem. Please contact me at (Edited personal information). If you need to discuss this or please reply to this request and I will follow the steps that you provide. Best Buy told me that you would reimburse or replace the modem due to their return policy. The modem is an SB 8200 and was purchased on January 4, 2025 or $169 plus tax from Best Buy and wyomissing PA store number 580
To help isolate the issue, we recommend connecting the modem directly to a computer using an Ethernet cable. Please ensure that only one Ethernet connection is active on the modem during this test. To check the Ethernet port status, you can connect the modem directly to a computer and check the IP address without the coaxial cable connected.
  1. Click on the Apple menu.
And as ​@plemans mentioned you could reach to us by our support platform.
  • July 23, 2025
You have to actually contact customer support. This is the user support forum where members of the public and some moderators help out.
https://www.surfboard.com/support/resources/
