Newly activated SB8200. Channel 24 is missing. 25 is not locked and 23 has 3127368446 Correctables
  • September 24, 2022
  • 211 views
I just had this activated last night and having some channel issues and only the downstream light is blue. The upstream light is green. Spectrum  says they don’t see any problems. Is this normal?
Then you’d need to check with the ISP as there’s something going with the line.
After bypassing the router and going straight to the pc, channel 24 appeared and is “Unlocked” at 0Hz, 25 is now “Locked” and channel 23 is still showing “Other” under “Modulation”. Weird stuff
  • September 26, 2022
usually indicates an issue with the line.
No splitters, amps or attenuators. It’s hooked up directly where the cable comes in.
