No lights come on SB8200
My SB8200 will not power up. The 4 lights on the back at the ethernet ports come on. None of the lights on the front work. I have tried moving to multiple different outlets and there are no changes.
Are you able to log into it or ping the modem from a hardwired in pc?
  • 2292 replies
  • July 26, 2023
Did you try disconnecting the coax from it and resetting it (while powered on)?
  • July 26, 2023
I did. There was no change. Still only the lights on the back by the ethernet ports illuminated.
  • 2292 replies
  • July 27, 2023
