no power to my surboard. why?
  • January 29, 2025
  • 81 views
I can’t get my surfboard to power up
  • January 29, 2025
did you check the power supply?
Is it new? Old?
Did you try a different outlet?
Could you please help us with the model number of your product?
As ​@plemans suggested please try different power outlets and also if possible please do try a different power adapter.
I would recommend performing a factory reset on the device. Please note that this will restore the product to its default settings.
