Rapid light blinking and no Internet SB8200
  • February 26, 2025
  • 99 views
I lost Internet connection. Unplugged it last night and when I plugged it back in last night all lights rapidly blinking intermittently. Tried reset and it did nothing. Unplugged it
Woke up this morning, plugged it in, and now zero lights. Front or back.
About 2 years old and I think it's done?
Might still be in warranty. Have you checked it?
Usually the all lights off or all lights rapidly blinking indicates a failure.
  • February 27, 2025
  • February 27, 2025
Thanks. It was dead. I bought a new one. Hopefully this one goes longer.
  • February 27, 2025
good luck! same model or upgrade to the S34 with xfinity’s next gen speeds?
