receive light not on
Hey everyone. I noticed my receive is light not on and thr other 3 are like a yellowish green. The internet still works but reading the manual says all the lights "should" be on. Anyone got any insight? Thanks!
Hello Curly815
                         SB8200 is a cable modem and the lights on the modem indicates the upstream and downstream signal sends to the modem by the Internet service provider,  so if you see any lights off or intermittent you need to check the signal level and also confirm with your Internet service provider about the signal strength of your modem. To test the cable signal level on the modem interface you can follow the steps mentioned on the link below,
Let us know if this helps
  • May 19, 2023
The upstream signal is just under the mark. Would that cause the receive light to be off?
  • May 19, 2023
  • May 19, 2023
SURFboard Moderator wrote:
Hello Curly815
I did a factory reset and xfinity was no help any other suggestions?
  • 2298 replies
  • May 20, 2023
got a copy of the cable connections page and the event logs? helps more than general light diagnostics.
  • May 20, 2023
What is cable connection page and where is the general diagnostics area? Sorry, not familiar with all this and this is my 1st time having this issue 🙏🏼
  • May 20, 2023
*events log
