I have Cox for Internet. Cox support told me to use a switch (not a router) to connect two computers to the modem. It seems like a simple thing to do, and I want to be sure to get a compatible switch. Any recommendations for a switch?
I'm also considering having a Cox technician come to my house to do the setup in case there are things I don't know that need to be done -- currently have their Panoramic modem/router. Is that a good idea?
Answer
Recommendations for a switch for SB8200
A switch won't allow you to connect two computers simultaneously on the SB8200, as both ports are assigned the same IP address.
To use a second IP address, you would need to subscribe to one from your cable provider. However, not all cable providers offer additional IP addresses for residential services.
