SB8200 addressable from Xfinity, but "No Internet" from home, need warranty process
  • December 6, 2024
  • 66 views
SB8200 was in service since August 2024 and under warranty.
In December 2024, “No Internet” status from all home computers.
All status lights (Power, Receive, Send, Internet) solid green, none flashing
Computer directly connected to the modem also reports “No Internet”.
Xfinity reports modem is fully addressable from their end (but lights never flash)
Approximately 3 hours Xfinity phone support and over a dozen modem/router reboots performed
IPCONFIG /RELEASE, IPCONFIG /RENEW performed, PING local network addresses successful, PING internet unsuccessful
Need process to return modem under warranty
You’d need to go through support.
https://arris.my.salesforce-sites.com/consumers/ConsumerProductSupport?t=Call&utm_source=SURFboardSite&utm_medium=contact-us&utm_campaign=surfboard-resources-call
One thing to keep in mind  is that even though the SB8200 has 2x ethernet ports, xfinity only supports 1 device connected to it. So if you have more than 1, try disconnecting everything from the modem, factory reset it , then power it off for arouond 10-15 minutes. Once that time has passed, power it on with nothing connected to it. give it a couple minutes. Then plug your router (just the router) into it. run through the setup process on the router.
what router do you have?
  • December 6, 2024
The Router is a Cisco/Linksys EA9200. I have since had Arris technical support perform numerous tests and have me returning it for a replacement. Thank You.
  • December 16, 2024
Glad they were able to get you setup with a replacement!
