SB8200 - All lights flashing rapidly
  • August 25, 2025
  • 176 views
My SB8200 does not work.  All lights are flashing rapidly.  I tried a different power supply, outlet, coax cable, and resetting it with no luck.  I think it’s dead.  It should still be under warranty, but I cannot find the serial number on the website.  Please help.
Since the issue persists despite completing the basic troubleshooting steps, I recommend checking the status of the Ethernet port for further diagnosis.
  1. Click on the Apple menu.
For further assistance, please contact our support team by visiting www.arris.com/consumersupport.
  • August 28, 2025
When I don’t have the coax connected there are no lights illuminated.  I also see “Media disconnected” in the Media State when following the procedure outlined above.  I tried plugging in the ethernet cable to each port on the back of the SB8200.
