sb8200 and optimum
  • February 24, 2025
  • 82 views
My sb8200 arrived today. I gave optimum tech support the mac and they say everything is set up and shows it should be working on their end. But it's not. The internet light flashes for a couple minutes then will go solid for about 30 seconds then it resets itself. I pulled the event log from the modem. Any one have any insight.
23/02/2025 22:11:54
critical
TFTP Request Retries exceeded, CM unable to register
23/02/2025 22:11:54
critical
TFTP failed - Request sent - No Response;CM-MAC=10:e1:77:71:01:f5;CMTS-MAC=00:01:5c:b4:c8:56;CM-QOS=1.1;CM-VER=3.1;
23/02/2025 22:08:51
critical
Config File Rejected due to Invalid or Unexpected TLV 11;CM-MAC=10:e1:77:71:01:f5;CMTS-MAC=00:01:5c:b4:c8:56;CM-QOS=1.1;CM-VER=3.1;
23/02/2025 22:08:51
critical
TLV-11 - Illegal Set operation failed;CM-MAC=10:e1:77:71:01:f5;CMTS-MAC=00:01:5c:b4:c8:56;CM-QOS=1.1;CM-VER=3.1;
23/02/2025 22:08:48
error
Primary lease failed, IPv4 fallback initiated;CM-MAC=10:e1:77:71:01:f5;CMTS-MAC=00:01:5c:b4:c8:56;CM-QOS=1.1;CM-VER=3.1;
23/02/2025 22:08:48
critical
DHCP failed - RS sent, no RA received;CM-MAC=10:e1:77:71:01:f5;CMTS-MAC=00:01:5c:b4:c8:56;CM-QOS=1.1;CM-VER=3.1;
23/02/2025 22:08:19
critical
No Ranging Response received - T3 time-out;CM-MAC=10:e1:77:71:01:f5;CMTS-MAC=00:01:5c:b4:c8:56;CM-QOS=1.1;CM-VER=3.1;
  • February 25, 2025
Your person who provisioned it might have registered it as the wrong device. Call them back and see if they can reprovision it
  • February 25, 2025
No joke I tried that with 10 different people over 2 days. They finally sent out their lead tech he told me and I quote get rid of that garbage. I've since returned the sb8200 and got a cm1200.
