SB8200 connected with Xfinity, I no longer have 2.4GHZ acce3ss
  • January 3, 2025
  • 121 views
How can we activate the 2.4GHZ on the SB8200 with Xfinity? I just bought the device and cannot connect some of my devices. Thank you for your help in advance
The SB8200 is a cable modem and does not have built-in Wi-Fi capabilities. If you're looking for Wi-Fi access, I would recommend connecting a router to the SB8200.
  • 2303 replies
  • January 4, 2025
You need a router for wifi. The SB8200 is a modem only device.
Did you purchase a router?
  • January 6, 2025
I did, I purchased a NetGear Nighthawk with a Google Mesh; all is good.
