SB8200 Excessive (thousands) of errors?
  • December 15, 2022
  • 587 views
I have a new SB8200 on Optimum 300 Mb cable internet. The modem is connected directly to the Optimum-provided cable in house, about a 10ft run to outdoor cable connection.There are no other devices bridging the cable. Internet only.
In looking at the Downstream Bonded Channels page on the webmanager, I see many thousands of Corrected & Uncorrectable errors on every channel. Generally 4000- 5,500 on each. Ch 33 shows 9,130,017 Corrected!
All channels are locked and show power of between 8.9dBmV to 11.8.
I do not notice any dropouts in service (streaming audio and video services) and my service for web seems steady, although not blazing.
This is many more errors than I’ve seen when others post. Is there a service problem?
You have a bunch of errors in your line and your power levels are to high. It should be between -7.5 and 7.5dbmv. Plus you have errors in the logs showing its going further out of spec. If its directly connected, the ISP needs to check the line.
  • 2275 replies
  • December 16, 2022
Melchior
The Certified
Forum|alt.badge.img+4
  • 14 replies
  • December 17, 2022
I am getting lots of corrected errors on channel
193 Locked Other 702000000 Hz -0.6 dBmV 39.2 dB 437895050 1327
is this a problem??
Melchior
The Certified
  • 14 replies
  • December 29, 2022
no replies from ARRIS? :-(
current stats below on that DOCSIS 3.1 downstream channel errors...
193 Locked Other 702000000 Hz 0.0 dBmV 39.0 dB 2167775147 134764
