SB8200 Firmware Updates Optimum
  • December 21, 2023
  • 1890 views
Where can you find the firmware ? I am at   AB01.01.009.51_080720_183.0A.NSH and I know there has been a newer firmware out there. Can my ISP update the firmware on my owned modem? Can you SSH into it to upload it?
  • 2275 replies
  • December 21, 2023
Modems don’t have user changeable firmware. Its part of the provisioning from the ISP. Nothing you can change or do. You can ask them for newer firmware but they’ll tell you they can’t or “arris needs to do it” just to get you off the phone.
are you having issues or why do you think you need to update the firmware?
