SB8200 - how to use the modem with ethernet input from ISP
  • December 3, 2024
  • 41 views
I have an ethernet cable input from my provider (Reliance Connects). How do I connect it to the SB8200 modem?
SB8200 is compatible only with a co-axial cable connection to access the internet. Ethernet cable input from your internet service provider is not compatible to access the internet.
  • 2219 replies
  • December 4, 2024
The SB8200 is a cable modem. If your provider has ethernet input, it isn’t a coax company.
