SB8200 Modem LED Lights
I just got rid of a 9 year old Motorola/Arris modem where the bottom light would “flicker” when the internet was working. I installed a new Arris SB8200 but I noticed the bottom “globe” light does not flicker; it just stays on steady. Is this normal?
Best answer by rsprentice
No, no issues. Just noticed that the “globe” internet LED light doesn’t randomly flicker like it did on my previous 9 year old model (my new modem is also a higher end model than the old one). Thanks for replying!
  • 2277 replies
  • August 9, 2023
Yes.
Are you having issues with it?
  • August 9, 2023
