SB8200 no internet connection, all lights are solid
Hi, when I first connect my modem and activated through Zito. The modem down stream turns blue, the rest are green. I have internet connection for about 7 months now, but 2 weeks ago my down stream light turns green. Now I have no internet. I was able to ping couple of sites like google.com.
I called Zito and they said they did maintenance on my signal remotely and all my signals are within acceptable range 27-37 SNR.
troubleshooting steps I took so far. None fixes my problem
  1. restart modem
  2. reset modem
  3. plug in to modem directly using computer/other devices bypassing router
  4. turn-off modem, unplug coax and waited 2 minutes. Reassembled everything in reverse order.
  5. tried different DNS in router
Best answer by Kanti123
So the technician came out and said it’s the node problem. Everything is working now, getting 200Mbps down 20up. Now all down stream are all in 40snr but upstream was sitting at 51-52. I hooked up the active return amp from arris BDA-42-1-AR-R and all upstream are down to 40. Not sure if I should leave it on there (I got it when I was desperate trying to fix my internet)
  • 2277 replies
  • July 12, 2022
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
do you have a screen snip of the cable connections page and the event logs?
  • 10 replies
  • July 12, 2022
Check the connectors forimproperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
I’ve already checked and replaced any bad connection. The cable coming into my house is connected to a connector to the wire that goes into the house. Then another barrel connector in the network box (not splitter) and the last one is the one at the wall out let. All of those a good.
  • 2277 replies
  • July 12, 2022
Not just “good” but you’ve actually unscrewed them and checked to see if there was any moisture, foil touching copper, kinks in the line, etc?
Do you have a screen snip of the cable connections page and event logs?
  • 10 replies
  • July 12, 2022
Yes, I replaced all crimped style connector with compression fitting. I even bought all the tools for it and I made sure the foils and wires are not touching the middle copper piece
  • 10 replies
  • July 12, 2022
Here the screen shot of my modem signals
  • 10 replies
  • July 12, 2022
  • 7 replies
  • July 12, 2022
It appears to be a common problem with DOCSIS 3.1 modems, at least I had the same problem with both a Motorola MB8611 and an Arri SB8200 replacing a Motorola SB6141  Had 5 onsite visits by more than a dozen Comcast “technicians” none of whom were able to diagnose or offer repair suggestions or remedies.  Comcast reported their monitoring showed my modem ALWAYS online while on my end I had zero internet service.  I eventually was pointed to an article by Brady Volpe of the Brady Firm discussing this very issue.  Rather than fool around with the reported DOCSIS 3.1 issue which Comcast obviously did not understand, I acquired an Arris SB6190 DOCSIS 3.0 modem which I will install once I return home.
  • 7 replies
  • July 12, 2022
  • 10 replies
  • July 12, 2022
Please keep me updated if that fixes your issue
  • 2277 replies
  • July 13, 2022
You do have errors in your line and your power technically in spec but a bit lower than I like to see.
You’ve moved it to right where the line comes into the home and connected it? This ensures it isn’t wiring within the home or connector thats causing the issue
  • 10 replies
  • July 13, 2022
I’ve tried that before and yea I was getting the same signal. I’ll double check it today when I get home. I went ahead and order another modem Sb6190 that is a DOCIS 3.0
  • 2277 replies
  • July 13, 2022
Docsis 3.0 doesn’t have the speed capability of docsis 3.1. And most ISP’s are dropping the speed tiers that they’ll support for docsis 3.0. I’d be working more with the ISP to get the line issues fixed or figuring out if its a modem issue versus dropping down to a 3.0 device.
  • 10 replies
  • July 13, 2022
For now I’ll see if it is docsis issue. Zito media uses docsis 3.0 and the max speed they have for me is 200Mbps. If it doesn’t work I’ll just return it to Amazon.
  • 2277 replies
  • July 13, 2022
Hope it works well for you!
  • 7 replies
  • July 13, 2022
Thanks very much.  The old Motorola DOCSIS 3.0 modem was working well and I should probably have left it alone but I had the hots for a new 3.1 modem which turned out to be a disaster.  I left A T & T 21 years ago and went to Comcast because of lousy internet connections and don’t know how A T & T is doing with DOCSIS 3.1 modems but in my area there are lots of complaints by Comcast customers with the same problem I had and no help from Comcast, so I wonder whether there is something inherent in 3.1 modems or perhaps limited to Comcast.
  • 2277 replies
  • July 13, 2022
ATT is either on fibre or on DSL. Not aware of att using any current cable setups. I’ve had great luck with docsis 3.1. But i have had to have comcast out to prove to them that it was their line and not my modems after I tried 2x different modems and had the same issue. Turns out a tree had kinked the line in the ground and they had to re-run it.
  • 7 replies
  • July 13, 2022
Thats far better than my Comcast experience…..I had the same problem a few years ago which eventually turned out, after 7 onsite visits to tell me my hardware was old and must be replaced, to be a break in the cable behind 2 or 3 houses down the street and one that section of cable was replaced the problem was solved.  Usually an onsite visit by Comcast “technicians” is primarily an attempt to con me into renting their hardware.
  • 10 replies
  • July 13, 2022
My problem was that I had scheduled two appointments for technicians to come out and both times they didn’t.
  • 10 replies
  • July 15, 2022
