SB8200 not showing DOCSIS. 3.1
  • February 10, 2024
  • 492 views
My SB8200 is showing all green middle lights indicating its running in DOCSIS 3.0. I called Optimum and they said it should be running in DOCSIS 3.1 with my 1 gig plan. Please see the connection log to see if there are any issues. I was using Optimums modem, but it rebooted multiple several times per day. I no longer have that issue with the 8200.
Connection
The status listed show the connection state of the cable modem. They are used by your service provider to evaluate the operation of the cable modem.
Startup Procedure
Procedure        Status  Comment
Acquire Downstream Channel            429000000 Hz Locked
Connectivity State       OK       Operational
Boot State       OK       Operational
Configuration File       OK
Security           Enabled           BPI+
DOCSIS Network Access Enabled        Allowed
Downstream Bonded Channels
Channel ID      Lock Status      Modulation     Frequency        Power  SNR/MER        Corrected            Uncorrectables
1          Locked 256QAM          429000000 Hz 1 dBmV           40 dB   0          0
2          Locked 256QAM          435000000 Hz 1 dBmV           40 dB   0          0
3          Locked 256QAM          441000000 Hz 1 dBmV           40 dB   0          0
4          Locked 256QAM          453000000 Hz 1 dBmV           40 dB   14        0
5          Locked 256QAM          459000000 Hz 1 dBmV           40 dB   3          0
6          Locked 256QAM          465000000 Hz 2 dBmV           40 dB   9          0
7          Locked 256QAM          471000000 Hz 2 dBmV           40 dB   0          0
8          Locked 256QAM          477000000 Hz 2 dBmV           40 dB   0          0
9          Locked 256QAM          483000000 Hz 2 dBmV           40 dB   0          0
10        Locked 256QAM          489000000 Hz 2 dBmV           40 dB   0          0
11        Locked 256QAM          495000000 Hz 2 dBmV           40 dB   0          0
12        Locked 256QAM          501000000 Hz 3 dBmV           40 dB   0          0
13        Locked 256QAM          507000000 Hz 3 dBmV           40 dB   0          0
14        Locked 256QAM          513000000 Hz 3 dBmV           40 dB   0          0
15        Locked 256QAM          519000000 Hz 3 dBmV           40 dB   0          0
16        Locked 256QAM          525000000 Hz 4 dBmV           40 dB   0          0
17        Locked 256QAM          531000000 Hz 4 dBmV           40 dB   0          0
18        Locked 256QAM          537000000 Hz 4 dBmV           40 dB   0          0
19        Locked 256QAM          543000000 Hz 4 dBmV           40 dB   0          0
20        Locked 256QAM          555000000 Hz 4 dBmV           40 dB   1          0
21        Locked 256QAM          561000000 Hz 4 dBmV           40 dB   0          0
22        Locked 256QAM          567000000 Hz 5 dBmV           40 dB   0          0
23        Locked 256QAM          573000000 Hz 5 dBmV           40 dB   0          0
24        Locked 256QAM          579000000 Hz 5 dBmV           43 dB   0          0
25        Locked 256QAM          585000000 Hz 5 dBmV           43 dB   0          0
26        Locked 256QAM          603000000 Hz 4 dBmV           40 dB   0          0
27        Locked 256QAM          609000000 Hz 4 dBmV           40 dB   0          0
28        Locked 256QAM          615000000 Hz 4 dBmV           40 dB   0          0
29        Locked OFDM PLC       690000000 Hz 5 dBmV           45 dB   3235604          0
Upstream Bonded Channels
Channel ID      Lock Status      US Channel Type         Frequency        Width  Power
46        Locked SC-QAM          17600000 Hz   6400000          41.0 dBmV
45        Locked SC-QAM          24000000 Hz   6400000          42.0 dBmV
44        Locked SC-QAM          30400000 Hz   6400000          42.0 dBmV
43        Locked SC-QAM          36800000 Hz   6400000          43.0 dBmV
Current System Time:Thu Feb 8 19:15:42 2024
Thanks for sharing the cable signal levels information, In regard to the LED light status and cable signal levels , please check the following information provided on the link below:
http://arris.force.com/consumers/articles/General_FAQs/SB8200-LED-Light-Status
Also, note the event logs are monitored by Internet Service Provider .
  • February 10, 2024
The table below contains the log of events that the SB8200v3 has detected. This log can be important to the service provider to help diagnose and correct problems, if any should occur.
Date Time       Event Level      Description
08/02/2024 19:15:40
notice
GUI Login Status - Login Sucess from LAN interface; client ip=[192.168.100.200];CM-MAC= -MAC= -VER=3.1;
08/02/2024 19:10:05
notice
GUI Login Status - Login Fail from LAN interface; client ip=[192.168.100.200];CM-MAC=CM-QOS=1.1;CM-VER=3.1;
08/02/2024 18:10:29
notice
SW Download INIT - Via Config file ^1/5E0945BA/1GIGRU/VER=D31
08/02/2024 18:10:24
notice
REGISTRATION COMPLETE - Waiting for Operational status;CM-MAC=CM-VER=3.1;
08/02/2024 18:10:19
critical
Config File Rejected due to Invalid or Unexpected TLV 11;CM-MAC= -VER=3.1;
08/02/2024 18:10:19
notice
TLV-11 - unrecognized OID;CM-MAC=VER=3.1;
08/02/2024 18:10:18
warning
MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=VER=3.1;
31/12/1969 19:01:06
notice
Cable Modem Reboot due to power reset;CM-MAC=VER=3.1;
08/02/2024 18:02:25
notice
CM-STATUS message sent. Event Type Code: 23; Chan ID: 29; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=VER=3.1;
08/02/2024 17:52:05
notice
MDD Recovery following MDD Loss;CM-MAC=VER=3.1;
08/02/2024 17:51:20
warning
Lost MDD Timeout;CM-MAC=VER=3.1;
08/02/2024 17:51:14
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=VER=3.1;
08/02/2024 09:55:18
notice
SW Download INIT - Via Config file ^1/AB2DC97E/1GIGRU/VER=D31
08/02/2024 09:55:14
notice
REGISTRATION COMPLETE - Waiting for Operational status;CM-MAC=VER=3.1;
08/02/2024 09:55:12
warning
REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC= -VER=3.1;
08/02/2024 09:55:10
critical
Config File Rejected due to Invalid or Unexpected TLV 11;CM-MAC=VER=3.1;
08/02/2024 09:55:10
notice
08/02/2024 09:55:10
warning
08/02/2024 09:54:48
critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC= -VER=3.1;
08/02/2024 09:51:06
notice
CM-STATUS message sent. Event Type Code: 24; Chan ID: 29; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=VER=3.1;
08/02/2024 09:50:48
critical
No Ranging Response received - T3 time-out;CM-MAC= -VER=3.1;
08/02/2024 09:48:43
warning
RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=VER=3.1;
08/02/2024 09:48:41
critical
08/02/2024 09:48:41
critical
No Ranging Response received - T3 time-out;CM-MAC=VER=3.1;
08/02/2024 09:48:40
warning
RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=VER=3.1;
08/02/2024 09:47:35
notice
CM-STATUS message sent. Event Type Code: 4; Chan ID: 20; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=VER=3.1;
08/02/2024 09:46:56
notice
08/02/2024 09:46:55
warning
08/02/2024 09:46:55
warning
08/02/2024 09:46:54
warning
08/02/2024 09:46:53
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=ER=3.1;
08/02/2024 09:46:50
warning
08/02/2024 09:46:48
critical
SYNC Timing Synchronization failure - Loss of Sync;CM-MAC= -VER=3.1;
08/02/2024 08:41:37
notice
CM-STATUS message sent. Event Type Code: 5; Chan ID: 4; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=VER=3.1;
08/02/2024 08:31:58
critical
08/02/2024 04:11:34
notice
SW Download INIT - Via Config file ^1/541E785F/1GIGRU/VER=D31
08/02/2024 04:11:29
notice
08/02/2024 04:11:26
critical
08/02/2024 04:11:26
notice
08/02/2024 04:11:25
warning
=00:01:5c:95:c2:4d;CM-QOS=1.1;CM-VER=3.1;
