SB8200 only light on is power and will not factory reset
  • July 18, 2025
  • 188 views
Pretty much the title. Have had the modem for many years. Got a new router and went to set that one up. I unplugged the power from the modem and then plugged in the Ethernet for the router. After the I plugged the power cable back in, the only light on is the green power light.
Please try the following steps to troubleshoot the issue:
  1. Change the power outlet to make sure it’s functioning properly.
  2. Use an alternate power cord to rule out any issues with the original one.
  3. If the issue still persists, try performing a factory reset.
  1. Click on the Apple menu.
