SB8200 reboots every 10 minutes when coxial isn't plugged in.
Testing the SB200 when only power and ethernet connected.  Unit reboots after 10 minutes.  Is this normal behavior when no coxial is connected?  This is my second purchased one.
Many thanks.
  • 2253 replies
  • April 24, 2023
Not 100% because I don’t have that modem but I’ve seen other devices that will go into a boot cycle if they don’t detect anything on the coax side.
  • April 25, 2023
plemans,
Thank you so much!  I greatly appreciate it!
