SB8200 Slow Intermittent Connection on Astound Broadband
Similar to other posts, I am experiencing very slow (less than 1Mbps) on a 1GB service through Astound Broadband over last several weeks.  Trying to figure out if it is the ISP, the modem or my wifi.  Not sure how to diagnose modem and hoping someone knows how to decipher this.
You have a ton of errors in your line and your logs indicate the same.
If these don’t help, the ISP needs to check the line.
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
  • 212 replies
  • October 17, 2023
Your signal levels are fine. The Signal to Noise is within spec, but at the lower end of the desired range. The question is, why are the uncorrected errors so high? I’d reboot and see what the uncorrected errors are at the end of an hour and report back. Also, what are you seeing in the Event Log? Any T3/T4 Timeouts? Any CMTS warnings? Don’t post any internal MAC information if you post a screen shot.
Additionally, to get a good speed check, connect your PC directly to the SB8200 using ethernet. Reboot the SB8200, and run the Ookla Speedtest locally, not in a Chrome or Edge browser window. Let us know what kind of speed results you get that way.
  • October 17, 2023
Thanks for your assistance on this.  Ran two speed tests, one direct from modem to computer and another using the ISP’s speed test via browser.  Ookla showed 40 Mbps down, 4.87 up.  ISP showed 34 down, 1 Mbps up.  My service should be 1100 Mbps down and 11 Mbps up.  Yesterday, the event log showed no events, but today, after modem reboot, there are many.  See screenshots.  ISP is scheduled to come out tomorrow.  Really would like to resolve this.
LoveMyLab
  • 212 replies
  • October 18, 2023
The T3 timeouts show there is a definite communication error between your modem and the Cable Modem Termination System (CMTS). You have other errors occuring as well that indicate connection stability issues. Once your ISP addresses the connection, I’d do a hard reset of the unit (with cable disconnected) and then connect and test again.
  • 2287 replies
  • October 20, 2023
  • October 27, 2023
ISP had equipment in our neighborhood that was bad. Once replaced speeds are back to normal.
LoveMyLab
  • 212 replies
  • October 27, 2023
Thanks for the update! Thought that might be the case.
