SB8200 soeed with Optimum
  • December 9, 2023
  • 346 views
Hello I've checked multiple times with my ISP, Optimum, who have confirmed they are providing between 900-1.3gb down on multiple occasions
I connect to an Archer AX21 (DOCSIS 3.1) with a cat5e and it gets 300mb down.
Ive tried connecting to the modem (SB8200) with a DIFFERENT cat5e and get 400mb down. I use the first cat5e and still get 400mb down.
I'm getting 40-50% of my ISP provided speed through the modem when directly connected . I also ran through support with Archer and they don't have any obvious solutions from their end since all the speed drop occurs before their product
In this case we would suggest you to perform hard reset on the modem then check speed on direct connection and also slow speed, intermittent connection or no internet access occurs usually out of cable signal level, out of acceptable range and it will be resolved after the power level are adjusted by the service provider. So for this we need to check the cable signal level to confirm what causing this issue to proceed further.
Here we are checking the way the signal comes from out to inside the home. There are some important things that should be within a specific range in order for the internet to work properly.
First, the SNR should be above 33 on all of them. The downstream power should always be between -15 and +15. The closer to 0 the better connection. Finally, your upstream power should always be between +45 and +51
Please follow the steps mentioned on the below article to to check the signal level on the modem interface.
  • December 19, 2023
They were able to bring the levels to within range, but the overall speed remains low. Increased from 3-500 to 5-700mbps on a 1gb plan
Could you let us know whether the slow speed connection is with hardwired connection (directly connected to the modem) or with Wi-Fi access while connecting with router.
  • December 20, 2023
Hard wired
If you are experiencing the slow speed internet connection through hardwired connection which is the modem connected to computer through ethernet cable, I suggest you to try with
Re provisioning the modem with your internet service provider.
Also share the cable signal levels to know whether all the signals are in range.
