SB8200 web manager responds to 192.168.100.1 AND 192.168.0.1
  • May 3, 2024
  • 338 views
When signing into the web manager tool for my SB8200 cable modem, it responds to both 192.168.111.1 and 192.168.0.1. This causes a problem for me in that a router in my network can only be managed using 192.168.0.1 and when that is entered, it only goes to the Arris login screen. I cannot get to the router no matter how I’ve tried.
Can I, as an end user, somehow delete the 192.168.0.1 IP address from my SB8200?
SB8200 is just a cable modem and it is plug and play device there is no advanced configuration on the modem can be done manually so deleting IP is also not possible.
please try resetting modem then connect router to the modem LAN port then try accessing router interface it still same issue persist please do share the screen shot wen you getting access to Arris interface while search with router IP.
